hi im fairly new to the converting process but have been dealing with computers and divx and so on for sometime. anyways i recently purchased a new DVD player [got tired of using my crappy PS2 for dvds] and the guy told me it supported SVCD but unfortunatly it only supports VCD, so my problem as you can probably guess is...whats a program i can use that will let me convert SVCD to VCD. i have used VCDGear to get the SVCD off the CD i burned and now i cannot load it in TMPEnc so whats another program i could use to convert that file i now i have [that i got from using VCD gear which is a SVCD] how can i make it a VCD??
P.S. i know i can use Nero and convert it that way...but i also have to do some editing to it before i burn it so that wont work.
thanks
-Syxx
also i just read some more stuff on the site, and i noticed that TMPGEnc may not be workin cause i didnt have PowerDVD installed [for the codecs] now i installed it and i get bit further....but now i cannot do any audio? it does not let me select the audio source with TMPGEnc now...whats goin on?
do i have to do that audio with another program?
thanks
-Syxx -
Make sure you have the audio codec's, but try this
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
A Question about Colorimetry when converting HD to SD
By seven_deuce offsuit in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2011, 08:20 -
I have a question regarding converting videos?
By speedy45 in forum Newbie / General discussionsReplies: 27Last Post: 13th May 2009, 23:06 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 15:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 12:41 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 10:06
