I'm posting this in 2 Forum Areas because of the importance of this security problem:
I saw this in the TV Show "The Screen Savers", some of you perhaps know this. There is a way to configure a webpage that when you visit it it will wipe files from your hardrive and it goes undetected by anti-virus software I believe. This only affects WinXP and the SP1 will fix it but if you do not want to install the SP1 all you have to do is re-name a file in WindowsXP to deactivate this security problem.
"The security hole involves Windows XP help. The hole lets anyone put a link on a website that can wipe out certain hard-drive directories.
If, for whatever reason, you don't or can't download the service pack, there is an alternative. There's a file you can rename or delete to fix the security hole. Here
are the steps:
1.Perform a search for a file on your C drive called "uplddrvinfo.htm."
2.Once you've found the file, delete it or rename it. Doing so will not hinder your ability to use Windows XP."
I just rename the file to "uplddrvinfo.htm.security risk deactivated"
Once you do this you will be safe
Results 1 to 1 of 1
I've noticed a flaw in a soundtrack, but what is it?
By takearushfan in forum AudioReplies: 3Last Post: 30th Dec 2011, 02:00 -
Need to wipe drive
By neworldman in forum ComputerReplies: 18Last Post: 19th Nov 2011, 13:24 -
Best way to wipe drive
By neworldman in forum ComputerReplies: 6Last Post: 22nd Sep 2011, 17:51 -
Wipe C: drive
By tcory in forum ComputerReplies: 2Last Post: 12th Dec 2010, 22:02 -
Is there a program like DBAN, that can wipe external hard drives clean?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 19th Nov 2008, 03:34
