Hi!
Everytime I try to load a "vdr" file into CCE 2.5 it quits without any message.
It`s strange because it worked fine some days ago.
Anyone who have a solution for this?
Thanks in advance.
JOB
Do you have virtualdub running in frameserver mode for that file when you load it? Someone can correct me if I'm wrong but unlike AVISynth, framserving through virtualdub requires the avi to be loaded into vitualdub (and whatever filters you want to use), frameserver mode started, then save the vdr file and frameserving will start. At that time, you can load the vdr into CCE. If virtualdub is closed, the vdr file will do nothing as nothing is being framserved through it.
If you knew this and are having another problem, disregard. Hope I helped. -
Make sure you have an audiotrack frameserved aswell, in other words dont choose no audio in Virtual Dub. You can always deselect the audio in cce, in fact some times it dont work if you don't deselect the audio in cce
Thank you very much, you solved my problem!!!!!!
When I select audio in CCE it all works fine again.
JOB -
Well, it worked for five minutes. Now it`s back to the same problem.
Please help me!!!!!
JOB
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
".mkv" to "DVD" with CCE encoder
By chrchr in forum Authoring (DVD)Replies: 17Last Post: 28th Jan 2010, 14:01 -
Guide wrong? "Converting a PAL DVD to NTSC using CCE"
By OliverGrey in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 02:47 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45
