I am trying to split a large .avi up into two parts so they can fit on one disc each, but all the software I've found to split up an .avi has to recompress it first, which takes many, many hours. All I want to do is cut the last half hour off of the movie! I have been using VirtualDub. Can anyone suggest a better way to split an avi up than to recompress two different parts, wasting about 10 hours of my life?
You don't need to recompress the AVI. In Virtualdub, under the Video tab swith the from full processing mode to direct stream copy, do the same with the audio tab. Select the portion you want to cut with the brackets, and hit save avi. A few minutes later, Voila! You're done.
AVI file length
By RonNYC in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2012, 18:47 -
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 09:08 -
Easy edit DVD video cutting out unwanted stuff without recompressing
By deadp0et in forum EditingReplies: 6Last Post: 7th Feb 2011, 08:49 -
AVI/Xvid->MP4/Xvid w/o recompressing?
By chconnor in forum Video ConversionReplies: 15Last Post: 9th Feb 2010, 17:47 -
edit w/o recompressing mpeg4 and wmv
By mrready in forum EditingReplies: 3Last Post: 29th Jan 2008, 09:56
