Hi, I have a bunch of divx avi files(tv episodes) that I want to convert to mpeg2 dvd. I want to splice all the files (12, 25 min. episodes) and put tehm on dvd. Now, I have to splice them all together while they are in divx before converting to mpeg2 right? Or convert them first and then splice together? Sorry if this is a stupid question, I don't even have the equpment yet, just trying to get some info^^;;; - thanx
Actually, either way can work. You can use Virtaul Dub's File-->Append AVI segment... command. Or if you have registered TMPGEnc Plus, or normal TMPGEnc with the MPEG-2 plugin, you can use the File-->MPEG Tools-->Merge & Cut function. I suggest the Virtual Dub way. TMPGEnc can be a little buggy.
Anyway:
Virtual Dub Joining
TMPGEnc JoiningHello. -
I was thinking that you could probably do it either way, and splicing the divx files does seem easier. thanks for your help
VOB Editing question
By jeffboyrd in forum Newbie / General discussionsReplies: 4Last Post: 9th Oct 2010, 11:47 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
editing question
By Noobmeister in forum Newbie / General discussionsReplies: 12Last Post: 1st May 2008, 19:19 -
Question on editing vc-1 file
By ultraman36 in forum EditingReplies: 2Last Post: 13th Dec 2007, 08:34 -
Tool for editing Divx
By ghassan99 in forum EditingReplies: 2Last Post: 18th Jun 2007, 19:02
