My second thread today, euhm
I bought yself a nice HQ s-vhs cable.. TV-out black and white, tv in black and white....
I gues you could call black and wite high quality *cough*
Results 1 to 9 of 9
Sounds like a bad cable, or not inserted all the way ( they can be fickle ).
check you didnt bend a pin also -- those things can be a royal pain trying to insert one in the dark behind a tv by feel ..
Is your video recorder or output device capable of producing a S-VHS signal? Is the device switched to S-VHS mode via scart using its on screen menu?
Aha, I haven't tried the on screen menu!
Thanks, but it also doesn't work from tv to vcr, I gues it's just thsame...
Thanks, I'll check it! -
Sounds like you don't have a s-vhs video. This cable will only work with a s-vhs video / device. If your device is not this the cable will not magically create a s-vhs signal so your left with just using a standard composite.
I didn't kow it was a special signal, I just thought it was a replacement cable for the av, god damned, they don't put this on the box!
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
For VHS/S VHS tapes 10 - 20 years old what aspect ratio should I use 3:4 ?
By fuzzblaster in forum Capturing and VCRReplies: 1Last Post: 10th Sep 2010, 17:27 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 09:19
