What is the highest bitrate any of you have SUCCESFULLY used in TMPGENC from AVI to VCD? I know it depends on a bunch of things, yes, like the source movement on screen, player used on, etc.,but I was able to set CQ_VBR at max 3700, 'highest quality', and 'high quality (slow)' rendering, non-standard VCD.
How about the same for SVCD?
TMPGENC XVCD help from the site recommends nothing higher than 2500 bitrate including audio...when using BitrateCalc, it says that I can do a 30 min VCD at say 3700!...however I think it will freeze my player.
Has anyone used, say VCD 704X480 at super-high bitrate?
From what I've learned so far, it's the standalone player that has to be able to handle the bitrate. You can make a VCD (XVCD) any way you want, but it's whether or not the standalone will accept it. Mine for instance won't accept above 2500kbps
Does Bluray support standard definition bitrates above DVD Maximum?
By VideoFanatic in forum Authoring (Blu-ray)Replies: 16Last Post: 14th Feb 2012, 17:27 -
Maximum Bitrate
By unity2 in forum Authoring (DVD)Replies: 17Last Post: 24th Jun 2011, 08:25 -
BD-RE maximum writes?
By doppletwo in forum MediaReplies: 1Last Post: 8th Aug 2010, 23:59 -
Maximum PC Magazine Subscription $3.99
By MJA in forum Off topicReplies: 1Last Post: 7th Nov 2009, 03:42 -
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 12:57
