Here is my problem i can download clips at my uni of films in avi (divx)format the size is usual 280mb. But in order for me to bring it home it has to be cut up in to pieces to fit on my zip disks(as there are no cd burners in uni only zip 100mb drive)
does anyone know of softwere to do this ?????
it would help me out alot
regards
kilika
no problemo amigo!
what you want to do is RAR (ie Winrar, a zip-like program) the program into multi parts! so lets say you got a 300 meg file. you can set winrar (e.z. to use btw) to make a .rar (ie. zip-like file) in 3, 100 meg parts. Then it will all fit on your zip disks. the file will end up being like movie.rar movie.r00 movie.r01 3 parts, 100 megs each. then go home, copy the files into a directory and extract with winrar and voila - your file in on yur computer!..
http://www.winrar.com (i am not affiliated with winrar so.. winace also works just as well http://www.winace.com)
Which freeware (or paid tool) to cut easily HD movies (MOV,MTS)in 2 pieces?
By innovator in forum Video ConversionReplies: 1Last Post: 27th Nov 2010, 04:16 -
What's the quickest/easiest way to cut something from DVD and DivX
By dsajkw in forum EditingReplies: 2Last Post: 2nd Sep 2010, 11:50 -
Looking for simple software to cut mpeg1 into many pieces in one step
By jimdagys in forum EditingReplies: 11Last Post: 6th Jun 2009, 04:35 -
Cut Divx without Re-encoding
By kman22 in forum EditingReplies: 8Last Post: 26th Nov 2007, 18:39 -
splitting an AVI into several pieces
By penguin74 in forum LinuxReplies: 1Last Post: 29th Oct 2007, 20:54
