  1. write error occured at address 004028A9 of module TMPGENC.exe with 008738E8 keep getting this error when at 99%, tried different movies and reinstalled tmpgenc, can anyone she light on the mistake I am making.
    Many thanks
    Nicola J...
    Jul 2002
    Erie, PA United States
    fudgey65,
    What version of TMPGEnc are you using? In version 2.57 this is a known issue and most of the time you can just ignore it. I just started using v.2.58 and haven't encountered it yet, so as far as I can tell it's been fixed in the latest version
    Warning! I'm baaaaaaaaack
    ontario ,canada
    I had the same problem with one avi.It would stall at %95.It turned out to be a bad avi. conversion from pinnacle.Made a new avi. file from pinnacle,and it worked fine.
    bmiller,ont.canada
  4. Thanks for the help.
    I am using 2.53 so I will upgrade - also think it may be a few bad movies I have downloaded - just done 3 conversions and it worked fine this time, will upgrade version and try again if this does not work will get another copy of the movie.
    Thanks for your continued help and support on this forum.
