I have DVD it se and i like it a lot, but i really want more features, like motion menus stuff. I also would like a program that can import a .avi in dv format.
Any ideas DVD complete looks ok.
Which one?
Which is cheapest?
Thanks in advance
- Goaliemanshark
DVD Workshop has more features than DVDIt SE or PE, ie, you can edit the clips you bring in, has motion menu backgrounds and motion menu buttons, has menu templates and alignment tool for when you make menu from scratch, will encode your AVI, or you can encode outside and just pass it through. It's still pretty easy to use. There's a demo at ulead.com.
The pros and cons for all the authoring programs is very subjective and I highly recommend you download the trial versions. I have DVD WorkShop and it is very flexible. You can roll your own menus. On the other hand with DVD Compete all the menu templates are fixed and is there for very limiting. DVD Complete will be coming out with a document describing their scripting language used in the menus so you can create your own. DVDIT PE offers AC3 audio. It all depends on what you want.
i like Pinnacle Impression DVD-Pro for simple but very flexable authoring program in the lessor expensive catagory ...
good features but i see reading your post again you want one that encode your stuff also -- this one can not do that ... -
Thanks a lot guys this should help i'm downloading the trial of workshop now. The difrence between workshop and complete is one more flexible than the other? Please explain more! Thx. A feuture of dvd it is that you can make a mpeg-1 dvd. I tried it and i loved the outcome. Thx in advance
-Goaliemanshark -
i downloaded the trial of workshop and it crashes every time i open an mpeg or avi. Help!
dvd authoring software
By devdev in forum MacReplies: 2Last Post: 20th Apr 2012, 04:36 -
authoring software
By anasa in forum Authoring (DVD)Replies: 4Last Post: 31st May 2011, 19:19 -
Need fast authoring software...
By snafubaby in forum Authoring (DVD)Replies: 4Last Post: 15th Feb 2010, 03:14 -
authoring software.
By Kibble in forum Authoring (DVD)Replies: 1Last Post: 4th Mar 2008, 10:30 -
Help on what authoring software to use
By neosatusneu in forum Authoring (DVD)Replies: 5Last Post: 6th Jun 2007, 18:57
