How long does frameserving take? I use virtual dub and when I start frameserv it doesnīt look like anything is happening. Is it working but I canīt see it or what?
It sounds like you may not fully understand what frameserving does.
A framserver simply 'feeds' the movie to another application.
In the case of VirtualDub when you start the frame server you have a small window with counters that just sits there appearing to be doing nothing, in fact it is waitng for you to start the next step.
At this point you should now start your encoder (for example TMPGenc), and open the same file that you saved in the frameserver.
The encoder will now start processing the movie from data served to it from VirtualDub and you will notice that the frameserver window is now showing activity. -
OK! Thank you very much for your help, that cleared one or two things for me. As you might have guessed Iīm new to this and also English isnīt my main lang.
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 19:57 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 17:12 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 21:31 -
Frameserving with Adobe Premiere to Procoder?
By Soulman in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2007, 06:01
