I am trying to burn Panic Room and both cd's are over 80 minutes. I am using nero to burn with and i have tried to overburn with normal 80 minute cd's and it hasn't worked. I have also tried burning with 90 minute cd's and get the same results...no luck. My DVD player will not play any cd's burned using Fireburner so i'm stumped on what to do. Does anyone have any suggestions for me? I know I can extract the content from the bin file and convert split the mpeg into 2 cds but if possible i would like to avoid that.
Any suggestions would be appreciated.
Thanks... oh i have a mitsumi cd writer and i haven't found my model on the site to see if it supports overburning and i checked the mitsumi web site and was unable to find any info on overburning.
Results 1 to 1 of 1
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Burning SVCD At 480 x 272, 1152 kbps ?
By Tham in forum Authoring (VCD/SVCD)Replies: 2Last Post: 16th Sep 2010, 15:21 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Svcd Burning
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Apr 2008, 09:25 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 10:06
