I currently am using a 1394 card with the TI chipset for my PC. After doing some research, it seems that there are some compatability problems with the TI Chipset (i.e., Canopus website). Any suggestions on a replacement 1394 Firewire card that does NOT use the TI chipset? Thanks!
I have one from CompUSA based on the VIA chipset. It has worked flawlessly in Win2K since it was installed. Best of all, the price was only $30 since it doesn't come bundled with a bunch of cripple-ware.
Here's the link...
http://www.compusa.com/products/product_info.asp?product_code=274516 -
I have a Chump USA pcmcia card that works well. Don't have a link, but it is the only one they put their name on for pcmcia.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Windows 7 (x64) and Set Tob Box Firewire (1394) capture?
By techiejustin in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jun 2011, 21:57 -
DV to PC -- Firewire Problems; 1394 vs. USB; Capture Software
By GrayStrickland in forum Capturing and VCRReplies: 1Last Post: 27th Apr 2010, 12:27 -
No Firewire/1394 on newer laptops ?
By Movie-Maker in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2009, 18:01 -
DVD player with Firewire (1394) out
By PizzaPete in forum Capturing and VCRReplies: 9Last Post: 23rd Oct 2008, 01:05 -
Questions about DV transfer and connectivity of Firewire/1394
By Movie-Maker in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2008, 14:46
