I've recently begun doing DFV editing. I'm using my firewire card to capture DV video from my cam and using Vegas Video 3 to edit and encode it to DVD or DV format.
My immediate concern is that the rendering process takes a LONG time when any effects are applied to the editted video. My machine specs are Win2000, Athlon XP 2200+, 1 gig of RAM.
For example, I have a simple video clip, with no transitions or anything, but I did apply a glow effect filter across the entire 1 minute clip of video. When I render it out to DV or DVD format (or any format for that matter), it takes about 45 minutes to render the 1 minute of video!! I noticed if I remove the brightness/contrast filter that it takes only a few minutes. I guess the video effects just take time to render ?? Some effects are faster than others I've noticed.
Has any noticed a signficant different in rendering time for video effects between the different programs (premiere, vv3, mediastudio, etc.)??
Thanks in advance.
Jeff
no they all take a long time unless you can render in hardware like what i have .. then its real time ... including preview..
it takes longer on a compressed file though like what you have compared to uncompressed .. ...
After Effects Encoding
By MI6 in forum EditingReplies: 1Last Post: 6th Nov 2010, 10:07 -
Video encoding speed slower than previously
By genak in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2010, 17:23 -
Which video editors do special effects like pan, zoom, speed ctrl?
By tluxon in forum EditingReplies: 1Last Post: 21st Jan 2010, 16:27 -
will a separate video card speed up video encoding?
By edong in forum ComputerReplies: 12Last Post: 21st Oct 2009, 17:37 -
How much speed gain for video encoding moving from sing core to quad?
By keesio in forum ComputerReplies: 9Last Post: 21st May 2008, 11:02
