i have just converted my first film onto a vcd, the problem is that the picture looks quite blocky in places, it seems fine when i play it on my small pc screen, but on a large tv is shows up quite bad, i have used tmpge to convert it, can anyone tell me if there are any settings in this program that may help reduce this problem, i have motion search set to highest quality but i dont know what else to try????
thanks pete![]()
what format did u cap in use the original then use high quality and cbr if your source didnt have noise or to much static then it should come out great
i downloaded as an avi file, then converted using tmpge, and then burned using nero, but the avi file was good quality and when i play the mpeg file on the pc its not bad, but no as good as the original avi file, thats why i believe it has lost someting during the conversion, i know you do loose a bit of quality but i was just hoping that there maybe another little trick that will make it better.???
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 01:06 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 04:52 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 16:41 -
FFMPEG too blocky
By IMC in forum Video ConversionReplies: 4Last Post: 3rd May 2009, 16:00 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00
