Hi
I downloaded Baise Moi and it has swedish subtitles. Is there any way to remove them and replace them with english subtitles?
Thanks unlucky alf
They are now part of the movie, apart from cropping them out, then increasing the size of the screen to add them back. There is not much you can do
thanks for the help. I should previewed the file. I will just have to delete it
divx subtitle to dvd?
By uniks in forum Newbie / General discussionsReplies: 6Last Post: 18th Sep 2009, 17:29 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 14:39 -
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 03:41 -
dr divx subtitle help
By dbzkid in forum Video ConversionReplies: 2Last Post: 3rd Sep 2007, 04:09
