Hello!
Sometimes when I try to add AC3 files (Rip from DVD) in SpruceUp/DVDMaestro I get "Corrupt AC3" message and file wont open.
Converting the AC3 to MPEG works fine thou.
Is there anyway to repair the AC3 file?
I use smartripper and DVD2AVI to extract the AC3.
AnonymousGuest
I just use smartripper to demux the .ac3 file and never had a problem yet, just use the stream processing tab and select the audio and check demux to extra file. Perhaps it's DVD2AVI that's causing your problems.
you may think this is odd but Maestro can have problems with long path names and file names ... probobly not your problem but try renaming the path and ac3 long file name to a shorter name ... ussually this problem is during compiling and/or creating a image .. i have it crash on names with a dash in them also ..
Corrupt mp4 file?
By The-Lion in forum Video ConversionReplies: 3Last Post: 23rd Dec 2011, 05:06 -
A corrupt file after sending a .3gp file via bluetooth
By ViDector in forum Video ConversionReplies: 3Last Post: 15th Aug 2011, 09:03 -
Corrupt DV Avi file
By Briansquest in forum Video ConversionReplies: 2Last Post: 15th Jul 2010, 12:01 -
DVP-NS55P lockups -- SOLVED -- old ffmpeg produces corrupt AC3
By timmus in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Nov 2008, 15:09 -
corrupt dv-file
By pdehon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Nov 2007, 08:24
