I used to be able to play my ripped .vob files with the ATI file player.
I had a computer crash, and re-installed everything. Afterward When I rip a dvd - the ati file player won't open the .vob files.
i get an error box from RManager ... could not open file XXXX.vob
I am using smart ripper - just like I did before, and installed the same file player I was using.
Anyone have any suggestions? am I missing a codec? are my ripping options wrong (I don't think they are) anyone else have this problem?
Thanks,
yes,
uninstall ALL the following in this order:
* capture card drivers (???)
* MMC software
* graphics card driver
Then, re-install them all again.
Play an actual DVD file, so tha ATI's software dvd player can make
or re-create certain post file setings or *.ini files or something like that.
These settings are necessary for future DVD player the next time you
pop in a DVD. In your earlier try, you may have overlooed this. Too
late to try now, as you've already create these settings/files when you
loaded up an stripped *.VOB file (ie, smartripper)
Hope this works.
-vhelp -
nirv117,
the reverse:
* MMC software
-vhelp -
Well I uninstalled etc ... and now my DVD player works again ...
But the file player still won't play .vob files.
I guess I won't worry about it. I also noticed it won't play AC3 files either. i thought it used to do that too.
Maybe I'll try removing everything again sometime ...
from ATI File Player to .mpg (or any format that fits WMM)
By croarta in forum Video ConversionReplies: 2Last Post: 22nd Dec 2010, 10:10 -
Playing subtitles off VOB file in Media Player Classic
By aduh11 in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2009, 14:44 -
Help with burning a .vob file to DVD so it plays on a dvd player
By Volume in forum Newbie / General discussionsReplies: 1Last Post: 1st Nov 2008, 11:41 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
VOB to viewable windows media player file
By thomas.rs in forum Newbie / General discussionsReplies: 2Last Post: 1st May 2008, 11:26
