I have a bin/cue file that I mounted using Daemon Tools. It plays fine, but I want to cut it, and whenever I load it into almost any editing program like TMPGEnc, it gets the video stream cut but when it gets to the audio stream, it freezes. I've tried using other bin/cue converters too, and I've even tried MPEG corrector. Does anybody know a way to fix this?
Results 1 to 9 of 9
Have you copied the mpg to your hard drive or are you just reading it from the disk image? If you've got the image mounted with Daemon tools than just drag and drop it to your hard drive.
If you want to use it in any mpeg editor after this you need to demultiplex it and then remultiplex it as a vcd or svcd, depending on what its supposed to be. When vcds and svcds are burnt a file header is added to the video stream. This can often cause problems when you try to edit the mpg, moreso with mpeg2 files. -
That sounds like a good idea. But when I drag and drop the image into my hard drive, it copies about 90% of it then it gives me an error saying:
"Invalid MS-DOS function."
Do you know how to fix this? -
Actually I just found out why it is not working. It's because there is a certain part of the movie that is corrupt. Whenever I try to copy, or edit the movie in any way, it stops at that part. So how do you fix corrupt parts in bin/cue files?
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
