anyone know how to configure a digital cable box to receive all the tv
channels
Last time I checked, it couldn't be done. I'm not sure if someone found a way to hack digital boxes, yet.
see i heard on excursion someone said that i can play around with the box and it will let you unlock the channels. someone that told me worked for adelphia or used to and they taught them and he said it was easy but cant tell me cause they made a promise so is this true at all? thanks
There's a way to hack satellite cable, but not for the stuff that comes through the hard lined coaxials.
The digital satellite method involves reprogramming the chip, so that it can receive all channels. It basically tells the card in your cable box that it's "testing" the signal and enables it to receive all channels.
As for digital cable, I think the way that the service providers monitor the bandwith is different. I don't know for sure, but I'm guessing that's why digital cable hasn't been hacked, yet. -
I think you have to get a new cable box that has already been hacked. And you don't necessarily need to pay for digital cable. You can get basic cable and use your hacked digital cable box and it should work.
Digital Cable is alot harder/impossible to hack since your feed can be turned off at the cable companies end. Satellite systems on the other hand is a joke to hack since everyone get's the signal except the channels are encrypted. Of course the encryption is very weak and easy to hack. I got an ExpressVu system (Canada's Dish Network) hooked up this weekend, half an hour later I was watching the Pay Per View fight free
-LeeBear
What Product to buy to view DIGITAL cable TV on my PC?
By trighap in forum Newbie / General discussionsReplies: 4Last Post: 27th Nov 2011, 16:48 -
digital cable = the new svcd format?
By mazinz in forum DVB / IPTVReplies: 38Last Post: 8th Jul 2008, 01:22 -
DVD recorder + digital cable question
By bigkromedogg in forum DVD & Blu-ray RecordersReplies: 3Last Post: 27th Sep 2007, 10:34 -
What will happen to analog cable after the digital switch???
By yoda313 in forum Off topicReplies: 5Last Post: 12th Jun 2007, 18:32 -
They want to sell me DIGITAL cable
By Faustus in forum Off topicReplies: 4Last Post: 11th Jun 2007, 09:03
