I know that using wine you can use some windows apps on a linux machine. But what I want to know is could you also use it to install and run visual basic apps too?
Sure, if you fancy helping with the development that is ...
http://sourceforge.net/projects/vb4linux/
I only know VB6 and SQL though. I dont know the "standard" linux languages like C and C++.
A bird in the hand is worth a foot in the tush-Kelly Bundy
Any other apps.... mkv->divx WITH 5.1?
By biggyk in forum ffmpegX general discussionReplies: 5Last Post: 26th Jan 2009, 12:03 -
Linux themed skin for DVD Rebuilder (for Ubuntu and Generic Linux)
By freebird73717 in forum LinuxReplies: 5Last Post: 26th Nov 2008, 20:27 -
Portable Apps
By chrissilke74 in forum ComputerReplies: 5Last Post: 29th Jun 2008, 10:04 -
Tested apps to speed up transition??
By willmoodom in forum Video ConversionReplies: 3Last Post: 9th Nov 2007, 20:30 -
Nero Linux 3 Delivers Blu-ray and HD DVD Data Burning Support to Linux OS
By BJ_M in forum Latest Video NewsReplies: 0Last Post: 28th May 2007, 10:23
