    Nevada
    I'm trying to join a small end AVI clip to a larger AVI clip in VDub. The problem is when I go to "Append AVI Segment" it gives me an error saying the frame rates are different. The main clip I made directly as a DivX Avi in VDub. The end clip I converted to AVI from JPEG using Video Studio 3. They were both created at 29.97 frame rate, but apparently the frame rates are different by decimals. For example, one may come out 29.9703 and the other 29.9706 or something like that.
    The question is how to I convert the end AVI clip to the same exact profile as the main clip so I can join them in VDub? I know Xing MPEG Encoder works great for those situations with MPEGs, but how do you do that with AVI clips?
  2. Open Virtualdub...
    Open Movie part you want to set framerate > Video > Framerate > Change To > type in setting (23.976 or whatever) > Audio > Direct Stream > Video > Direct Stream > File > Save AVI
    "Today is only yesterdays tomorrow"
    Nevada
    Thanks! Got it to work.
