  1. I just tried to make an SVCD... it went through scanning the files, worked fine. Then it generated the XML file. That worked fine. Then it just said "VCDxBuild.exe" execution Failed!
    What does that mean? and how can I fix it?
    sorry if its a big vague....
  2. Never mind!! I just removed the files one by one and re-executed it in between and managed to find the file that was causing the problem!
  3. What program were you using? If you were using VCDEasy, did you have a look at the log file (was the log file setting on "verbose")?
    Regards.
    Michael Tam
    w: Morsels of Evidence
