Hello,
I had this problem with a dvd called, "Drugstore Cowboy" and it is why I stopped making VCD's.
The voices of actors were a little too low and they sounded demonic.
I recently made a vcd from a dvd with no audio problems, however, with the movie, "tape" I now once again have this strange audio problem?
I used smartripper 2.41, dvd2avi 1.76, tmpgenc 2.58, and nero 5.5.9.9.
I am making an XVCD. My settinngs are: 29 frames, 2000kbits, audio 192, 16:9 ntsc, vcd (non-standard), highest quality very slow, 352x240, full screen.
I encoded the video and audio separately to .mpg with Tmpgenc 2.58,
Then multiplexed them together with mpeg tools, then cut it in half, and burned with nero.
I also encoded the audio at 128 to see if that would change anything and it was still low pitched sounding?
Any help would be greatly appreciated.
Spanishfly
Forgot to mention that I encoded the audio from .wav to .mpg with mpeg tools after dvd2avi creates the .wav file.
hi Spanishfly,
I think this is caused by the sampling frequency. I had this problem before also when the audio was set to 48khz instead of 44.1khz. The pitch was lower and also out of synch too.
ren -
Thanks a lot Ren for the input.
You are right my frequency was set to 48000.
That must be it.
I am going to try it at 44100, hopefully it will work.
Thanks again,
Spanish Fly -
Try and use a program other than tmpg to downsample the audio frequency. Tmpg is know to introduce a metallic echoey (is that a word?) sound to the file when it changes frequency. I personally use dbpoweramp, but there are many others that can be used... There are also ways to set up tmpg to use an external audio encoder by going to options - environmental settings - external tools.
I've got a question about audio editing, like isolating certain sounds...
By darkzero297 in forum AudioReplies: 8Last Post: 9th Feb 2009, 21:34 -
Nero Vision 4 Audio Sounds Overdriven, Distorted
By norton833 in forum Authoring (DVD)Replies: 3Last Post: 12th Aug 2008, 18:23 -
Audio Sounds Muffled
By NBninja8 in forum Capturing and VCRReplies: 1Last Post: 26th Jan 2008, 00:53 -
DVD audio sounds high pitched
By nopulse in forum Newbie / General discussionsReplies: 3Last Post: 19th Nov 2007, 20:31 -
Newbie question about the audio sounds of my PC
By jeanpave in forum AudioReplies: 5Last Post: 12th Sep 2007, 01:32
