How the best method to extract audio from dvd? I used dvd2avi, but it's slow. How to convert ac3 to wav without dvd2avi?
Paradebh, DVD2AVI is probably the easiest way without ripping the DVD differently.
Alternatively, you could try ripping just the specific soundtrack on the DVD into an AC3 file. You can then use AC3DEC to decode it into a wave file.
Regards.
Michael Tam
w: Morsels of Evidence
Extract Audio from DVD Files
By foochuck in forum DVD RippingReplies: 7Last Post: 19th Jan 2010, 05:11 -
Audio Extraction from dvd's... best, effective and accurate method?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 25th Mar 2009, 13:34 -
Extract / isolate 5.1 audio tracks from DVD
By soundchaser in forum MacReplies: 0Last Post: 16th Mar 2009, 12:21 -
Audio is too slow after I extract files from DVD
By DJL82 in forum AudioReplies: 5Last Post: 6th Sep 2008, 18:43 -
Any 1Click Blu-ray / HD-DVD method to extract selected Video/Audio streams?
By jmone in forum DVD RippingReplies: 3Last Post: 2nd Jan 2008, 10:12
