When i import subtitles into DVD Maestro is there an option to change the subtitle display colour like white text with black outline, I've used Scenarist before and you can do this. or do i need to specify different colours in Subrip when i rip them as by default it gives them all a horrible red outline
It's ok i've finally found it,
Right click and edit one of the subtitles and change colour palette -
how do i rip the subtitles to get them into maestro i was going to do my own post but noticed urs so thought i would barge in
Rob,
You use subrip as it can output in maestro format, have a look at
http://www.doom9.org/mpg/dvdsubs.htm
and
http://www.doom9.org/mpg/maestro.htm
hope this helps
Just finished doing We were soldiers with two sets of subs and it works great -
posted on the 9/9 news @ doom9 also;
Sub2stl converts MDVDP and SubRip subtitle files to the STL format (DVDMaestro).
the link is there at http://www.doom9.org
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 22:11 -
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 12:42 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 02:32 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 04:22 -
Help! DVD Maestro RealTime preview. Cinemaster not working.
By IJM in forum Authoring (DVD)Replies: 10Last Post: 1st Jan 2009, 04:22
