So... I try to convert Memento.avi (DivX) to mpg and what happens? TMPGEnc complains about the Audio.
OK... I know this can happen, and I have read the post with solutions to this problem.
I have to "rip" the audio out first with VirtuaDub in wav format and combine the lot later.
Problem:
At the very end of saving the huge WAV audio file VirtuaDub
f.....g crashes!!!
I know that the first time i ran VirtuaDub it complained about the codecs i use, calling them "beta" or "unofficial". Is that what is causing it to crash?
Is there another program I can use to rip the audio off?
Is there another program as good or preferably a lot faster than TMPGENC ???
Thanks.
Did you set audio to full processing mode and compression to PCM audio? When I try that VirtualDub crashes after extracting 99%. When I set audio to direct stream copy and save it as an mp3 there are no crashes.
Regards,
Willem
Dual Layer burn issue with TMPGEnc Authoring Works 4
By am_dew in forum Authoring (DVD)Replies: 3Last Post: 7th Feb 2012, 08:36 -
TMPGEnc "clip total bitrate too high for a DVD-Video" issue
By dread in forum Authoring (DVD)Replies: 7Last Post: 26th Oct 2010, 15:34 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 17:53 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 10:00 -
Avisynth/TMPGEnc Xpress Audio Sync Issue
By Borflex in forum Video ConversionReplies: 4Last Post: 2nd Jun 2007, 14:10
