i just ripped a dvd to avi and it works alright but if i try to skip forward the sound is thrown off, the sound is ahead or behind by 10 seconds or so. what can i do to fix this problem?![]()
Does this happen only when you skip forward ?, the number of keyframes may be few, so playback would be a problem if you tried to skip forward.
But the AVI may be just fine.
Keyframes every 10 would make the AVI better -
yes it only happens when i skip forward. the movie plays fine until i do that
This is normal for movies that have been made with a small amount of keyframes. Movies with keyframes every 10 are much better, but smaller files with keyframes every 300 are no use to skip forward, but they will convert ok
Depends
If you intend sharing the AVI, then there could be problems. If the person who downloads it gets problems with the download, the AVI may have junk frames added. If your perfect AVI now has junk frames, keyframes every 300 will cause a lot of problems. Sound sync and difficult to edit and remove frames at the nearest keyframe.
So keyframes every 10 would produce a good AVI and make it a lot easier to edit if necessary.
On the other hand, if the person gets a perfect copy and is going to view it from start to finish, or convert it to VCD then keyframes every 300 would be fine.
I personally set them at every 10
If you don’t intend sharing it, why is it a AVI
and what is it, so I can download it also
Oh, did you use MP3 or AC3 in the AVI, MP3 would be better "For other people"
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
Win DV sound prob
By prcole18 in forum Capturing and VCRReplies: 7Last Post: 14th Jul 2008, 16:07 -
sound prob on dvd from mkv
By umpaflumpa in forum Video ConversionReplies: 2Last Post: 20th Dec 2007, 12:02 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 06:33 -
MPEG DV prob
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 24th Aug 2007, 18:01
