I captured two tv shows (30 mins each) in mpeg2 format. I used TMPEG - latest version - to convert to SVCD and then cut out commercials. Each file (22 mins) is 415MB! I can't fit two shows on one CD. What am I doing wrong? Shouldn't you be able to fit more than 44mins on one CD?
I used the SVCD template that TMPEG came with, and toolame.
You can't fit 830 MB on a 80 min cd, only about 795 MB.
When making SVCD is it the bitrate that decide how much you fit on a CDR not the playtime. Use a bitrate calculator to calculate the bitrate before so you know how big it will be www.vcdhelp.com/calc or any other.
Dvd with subtitles and Audio tracks in one big vob file help converting
By jimbobob84 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 02:09 -
Converting an MPG file to an ISO file.
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Dec 2009, 21:58 -
converting mpg file to MP4
By bdaul in forum ffmpegX general discussionReplies: 6Last Post: 16th Jul 2008, 16:54 -
Converting VOB file to MPG
By weenie02000 in forum Newbie / General discussionsReplies: 8Last Post: 5th Feb 2008, 13:58 -
Converting a mpg file
By galehickey in forum Capturing and VCRReplies: 5Last Post: 28th May 2007, 09:03
