Hi; very simple. I have some movies in my pc that I would like to play in my PS2. What do I need to do in order to do this? Do i convert them to VCD and them burn them?. Am i missing something?.any help will be really appreciate. Thank you before hand.![]()
la ciencia sin conciencia es la perdida del alma
Very simply you should have searched before you asked. PS2 can not play VCD, SVCD, you would need to burn your movies onto DVD-R in DVD format. No other way and not with the mislabeled JadeVCD PS2 kit. Even if you went that way, you'd need a modchip.
Thank you, I have been told from other people that I have to transfer the movies to VCD and play them in the PS2. Anyway I will check about your answer. Thank you alot.
Which way to Transfer Movies between computers quicky?
By SingSing in forum Newbie / General discussionsReplies: 1Last Post: 9th Dec 2010, 16:29 -
Connecting HDD to PC - Transfer Movies
By ZiGGY909 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 1st Mar 2009, 14:38 -
does the playstation 3 play divx or xvid files?
By Onceler2 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Aug 2008, 13:25 -
transfer movies to pc
By mzp3769 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 20th Feb 2008, 10:44 -
Can a playstation 2 play mkv files??
By goodvash in forum Newbie / General discussionsReplies: 6Last Post: 9th Aug 2007, 08:00
