I have the Apex 500 no-letter, looks like the 500WM but had the -1MM bios. Was getting what looked like a frame drop problem, either in capture or IVTC, or so I thought.
Finally got some time to do some analysis, problem NOT in original cap file OR in converted MPG, on DVD looks like 2 to 5 frames suddenly accelerate, effect does not occur in slow or stop motion, but does happen consistently at same spot. Does NOT happen on VCD. Effect is almost subliminal, usually get a couple per movie.
Had close-up of train wheels starting up, you know how you see them slip a bit when they start to move? This looked just like that, except the source video showed a smooth, gradual progression, no slip.
Upgraded to Apex 660 Bios from CD, easy upgrade, this has eliminated the problem. What an easy fix!!!
Results 1 to 1 of 1
Lg-bd630 stutter problem solved!
By RogerTango in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Feb 2012, 15:18 -
MPEG-4 frame skip problem - any way to fix it?
By TMHKR in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 08:42 -
DVD Architect pro 5: problem with playlist, brancing and next (skip) button
By alfini in forum Authoring (DVD)Replies: 0Last Post: 25th Oct 2010, 07:28 -
Menu swapping with IfoEdit - Problem solved
By Bingo-days in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 04:07 -
ffmpegx Avi to DVD frame skip problems
By Wellsie in forum ffmpegX general discussionReplies: 6Last Post: 15th Aug 2007, 18:58
