I want to convert this dvd to svcd using dvd2svcd. The movie is 201mins[pal], what will the quality be like if i want to put this on just 2 80 mins cdrs and what settings should i use, ie bitrate.
cheers.
Use TMPGenc to see what the default SVCD setting should be.
Have a look at http://www.vcdhelp.com/convert.htm which has lot's of info on this subject.
That's gonna be quite a difficult task to make 201min movie to fill just two 80min CDR's. You'd have to use 352x288 resolution and pretty low CQ, about 60-75 i'd say with bitrate around 1150. Try some of the Sefy's templates or
try 2-Pass VBR?
I made 180min movie to 2x90min CDR (352x288, 224kbps, CQ_100 bitrate 1300) and the quality was as good as you can expect.
Just my two cents,
Cosmo
Research finds many women need alcohol to enjoy sex
By zzyzzx in forum Off topicReplies: 0Last Post: 2nd Oct 2009, 14:52 -
More women needing cash go from jobless to topless
By zzyzzx in forum Off topicReplies: 9Last Post: 3rd Apr 2009, 03:31 -
Article really needs pics of the two women involved
By zzyzzx in forum Off topicReplies: 3Last Post: 3rd Mar 2009, 18:44 -
Oh! women!!!
By moviebuff2 in forum Off topicReplies: 1Last Post: 27th Jan 2008, 00:38
