Hi
First: my english is not good but i do my best.
I have a problem with my DVD Player Cyber Home DVD 402.
I canīt play Films that i take from Net. (E-Donkey)
The Player shows SVCD or VCD on Display but he dont play it.
Who can help me please?
I burned it with Nero 5.5.9.9 at Data Mode 2 or as an Image.
Some Films run and the most one not. The player shows also PBC on, the play sign is on too but it dont play it.
I hope you understand me and can help me.
Oh by the way how can i make it code free ? I show in DVD Hackz but i cant find any information about the 402 Player.
Thanks for Help.
Results 1 to 10 of 10
What file structure do you see on the disc when you use Windows Explorer?
Hi
in win explorer i see mpgav / svcd and vcd 2.0 .
A friend burned the cdīs with Nero in data mode 2 and they dont run.
I create a new vcd with nero (Sturart little 2) and now they run but the other one i have, i cant creat a new vcd nero write incompatible disc format.
Mr. Deeds shows as a vcd 2.0 but nero do not create a new vcd.It will alwas the file new encode.When i encode it i have the same problem on my Player.
thanks.
cu Tom -
mmmh!
A VCD should show the following directories:
CDI
EXT
MPEGAV
SEGMENT
VCD
A SVCD should show:
EXT
MPEG2
SEGMENT
SVCD
Using Nero you should use the VCD or SVCD compilation to burn your mpegs. -
Hi
yes this directorys are shown on the display.
in my nero version wasent the SVCD plug in installed, yesterday i installt this plug in and now can i re encode the file and the films are running.
thanks for help.
great.....
cu Tom -
When you get your files from the net, what format are they in? It sounds like you are encoding them twice, which is a lengthy process, and will result in a drop in quality. The SVCD plugin for Nero is to allow it to encode to (S)VCD, and really it is not the best tool for the job. It is a good burner, but a poor encoder.
hi
right it takes much time and the quality is a bad.
The files are bin and cue files, i think mpeg.
The problem is : a friend take the films from net and burned they with Nero as Data Mode 2 , his player plays the films, another frinds player too, but my player not. it begins to read the disc shows VCD or SVCD but then stop it.
I become Stuart Little from him , it was not running.
I read the cd withe nero as vcd, burned it normal as vcd and now it runs.
I dont know why he burned the files as data mode 2 they are bin and cue files.
when i burned a cue / bin file nero automaticly burned it as vcd or svcd why must he take data mode 2?
i cant take the fils self from net, my E-Donkey gif me a download from max 10 , it takes 2 -3 weeks for a film and this is shit....
i take max download 0 , max upload 11 , line speed down 96 , max connections 300 , on windows xp .
I have an Athlon XP 2400 , 1500 MB Ram this must be enough or not?
i think i must live with this problem. -
I frequently get SVCD in bin/cue format. What i do, which always seems to work, is extract the mpg using Isobuster. Then I run this mpg through TMPG's mpeg tools and use the simple multiplex option (SVCD option). I give the output file a new name, and burn to SVCD using Nero's SVCD option.
If I wanted something quicker, I would use CDRWin to burn the bin/cue files direct, but the former method is more reliable. -
thanks, i test it with isobuster and your method.
by the way are the settings that i use in e-donkey ok?
or how can i find informations about the settings for the donkey?
once i take a filme from e-donkey and burned this it runs perfekt.
but now i cant take any films from it and when i can get a film a message shows corrupted not complete , and this files do not run.
Not on PC and not on my Player.
I installed my complete System new and the Donkey too, but nothing has changed.
cu -
I can't help you with edonkey. All my DivX I create myself, or get from usenet.
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
VCD o SVCD with extra data (installers)
By pmaril in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th May 2008, 18:17 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
