I record many tv shows, which are in mpeg1 (320x240, video bitrate=1.75mbit, audio=44.100) format. But now, i want to get rid of all the dumb commercials, so i decided to use virtualdub (latest version) the first file is fine, but when i go to make the second and third file, the audio is out of sync! I even tried TMPGEnc (latest version) and the same thing happens! The first file is fine, but the rest are all messed up! HELP!!!!
Use VS6 to cut the samples then re-edit them......... cutting anywhere will lead you to OFSync......
"OO"P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo -
What is VS6 and where can i find it/download it? And wut do u mean by re-editing the files?
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
mp4's edited (merged) but audio out of sync
By stiltsky in forum EditingReplies: 2Last Post: 15th Sep 2010, 09:41 -
Restoring edited video.
By drummer in forum EditingReplies: 5Last Post: 9th Apr 2010, 05:57 -
Trying to sync audio with edited video, problems with encode....
By Jensen in forum EditingReplies: 1Last Post: 5th Jan 2008, 08:20
