and it turned out shitty. It was 44MB for 2 minutes, which sounds about right for a .m2v, no? But the weird thing is, it wasnt listed as a .m2v but rather just an mpeg. The sound is REAAAAAAAALy low even tho i turned it up while recording. I set the capture at 480 by 320 or something like that for ntsc in virtual dub, and then converted in that tmenpedfgfdfgd whatever it is prog. LOL - i need help - i must be doing something wrong.....
What program did you use to capture the video, and did you use a template to encode with TMPGEnc?
Hello. -
to capture - virtual dub
did i use a template? - im not good with this kind of thing- i have no idea.. -
Remember, we newbies need to read the newbie guides to get our bearings. Anyway, after you have captured your video in Virtual Dub.
Load TMPGEnc. If the wizard opens, close it (for now, anyway
). For the video input select your Virtual Dub-ed video file. Select Load. When the Open requester pops up, select the NTCS template.
Select Start. What does the finished file look like?Hello.
What is the BEST Mpeg 2 Encoder Today?
By jrodefeld in forum Video ConversionReplies: 43Last Post: 2nd Jul 2011, 16:28 -
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 22:05 -
Womble MPEG-VCR free today @ GiveAwayOfTheDay
By lordsmurf in forum Latest Video NewsReplies: 11Last Post: 25th Nov 2009, 07:05 -
Can't play PCM audio from MPEG made from MKV
By brianp6621 in forum AudioReplies: 10Last Post: 19th Oct 2009, 13:12 -
Convert mpeg-4 to wmv with super
By Kalash109 in forum DVD RippingReplies: 2Last Post: 17th Nov 2007, 07:14
