I have a question about the Panasonic dmr-e30.If I made a dvd to dvd-r copy of a concert dvd and selected the dts audio playback on the source disk.Would the dvd-r copy record with dts playback.I have searched the forums and have'nt found a post on this topic.
Thanks,![]()
The DMR-E30 has only analogue audio inputs.
A DTS stream is digital data.
In otherwords, there is no way to input that digital data stream into the E30, or any other set top DVD recorder for that matter.
Trying to use a DMR-E30 to record DTS is like trying to use a tape deck to save Excel files. -
If DTS is more important than the simple of ease and more faetures a desk top player has over a computer burner, like timer, tuner, editing, hook directly to DVD Player, laser disc, Dishnet, wirless remote, works just like avCR compared to the computer burner, then you should buy the Computer burner, specially if you have time on your hands to rip, author and burn these copies.
Any setup will only do 2.0 Dolby digital, which means your only gonna get Dolby surround, or THX Dolby Theater surround, no 5.1 DTS or 5.1 DD, mosts disc I have found, unless its a high octane action film or Disney don't much advanage of the 5.1 DD anyway and anything before 1993(before DD and DTS hit the theaters) you not goona get much of an advantage anyway, because almost all movies before that were only Dolby Digital anyway, sure a few today they have nehanced those soundtracks to simulate 5.1, most don't do a very good job.
Question with Panasonic DMR-EH75V...putting videos on hard drive
By tucold in forum DVD & Blu-ray RecordersReplies: 2Last Post: 17th Jul 2014, 14:21 -
Panasonic DMR es10 working question
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 24th Mar 2012, 19:02 -
Question about USB recording on the Panasonic DMR-EZ48V
By afroconnection in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Sep 2010, 10:06 -
panasonic dmr E30 compatibility
By jimakros in forum DVD & Blu-ray RecordersReplies: 5Last Post: 22nd Dec 2008, 13:19 -
dolby DTS
By natty in forum Newbie / General discussionsReplies: 8Last Post: 15th Sep 2007, 21:52
