Hi,
I am trying to figure out the process of video capture and editing.
I was wondering how much importance the capture card is.
I have a Hauppage TV tuner card and a
Asus Ti200 video card ,both with s-video input.
I seem only to be able to capture at a low resolution (320x240 with yuy2).
Thats with Virtual Dub.
Does the program read what your cards is capable of capturing.If I change the capture properties I get an error message.With Priemer 6 it completely locks and I have to shut down the program.
Also I cant seem to get the capture working for the Asus card. I dont know why ,but thats another issue.
Sorry about the long question,but do I need a different/better capture card?
I have an analog Canon Hi 8 recorded that capture really good video.
Thanks, Brad
I guess I really want to know if my cards suck for video capturing.Do I need an expensive vidio/capture editing board?
No. I have one.Originally Posted by Brad1140
No. I find vdub very adequate for simple stuff like removing commercials, etc.Originally Posted by Brad1140
I have a wintv fm radio card and I am very satisfied with it. I can cap at 400x480 with compression (see my weak computer details) without frame drops. I use the btwincap driver ( btwincap.sourceforge.net ) and have recommended it to anyone who has asked me. Your card WILL cap at a higher resolution. It may be the supplied drivers. -
Thanks fmctm1sw.
Thats the kind of info. I needed.
Now I see that the driver sets the maximum resolution.
I assume that I change or add a driver in the Control Panel>Hardware>Video>Legacy Capture section. -
If you are installing the btwincap, just follow the instructions that are on the web page. Also remember, you supplied tv apps may not work after you install this driver (a small price to pay in my opinion).Originally Posted by Brad1140
Yea,I lost my ability to use my TV Tuner.And my FM Tuner.
I really want to do both.
Can you tell me why I loose that ability.
Also I tried to reinstall the tuner driver and I couldnt figure out where it was or how to open my Haupagge card to even chose what driver.I would get an error screen before the tuner could open.
Is it under the legacy section.What does legacy mean anyway?
Can I just switch the drivers when I want to capture and when I want to watch tv?
Also I downloaded the drivers from the Haupagge site and went through the reinstall and they seemed to load but then the didnt load.
Do you know why .
The Conenant BTPci drivers seemed to stay as the loaded drivers.Is there anyway to swithch between drivers?
Sorry about all the questions. The drivers totally confuse me.
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
New "editing box", need advice on best use of multiple video cards.
By jaybird in forum Newbie / General discussionsReplies: 0Last Post: 10th Apr 2011, 22:16 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 09:03 -
Using 2 Hauppauge Capture Cards
By ddpool58 in forum Capturing and VCRReplies: 35Last Post: 21st Aug 2009, 22:53 -
Help with Video/Capture Cards.
By drsimp12 in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2007, 07:05
