I am a big fan of VirtualDub and use it to increase volume levels in AVIs (as well as the full range of video editing and encoding functions), and use it in conjunction with tmpgenc to comvert to VCD mpgs.
I have been searching for a way to clean-up the audio stream (somewhat like using a stand-alone graphic equalizer would). I can find nothing - there are a thousand video and audio encoders but nothing that I can find to do more than increase volume levels on outputed WAV, mp3, mpg and avi audio files. Is this possible with tmpgenc or virtualdub?
Does anyone have any recommendations?
Mike (tommyrex@knology.net)[/b]
Try Sound Forge or GoldWave. If you know someone with one of soundblaster Live! audio cards then they have it so finding a copy of SoundForge to copy should be pretty easy.
I mostly do music videos anyway so when the sound is bad enough I try to replace the crappy audio with CD audio, and I usually succeed.
What do you use to clean your system?
By Banleno007 in forum ComputerReplies: 4Last Post: 17th Feb 2012, 18:51 -
Tools Needed Clean up iPhone Concert Video's Audio
By xr280xr in forum Newbie / General discussionsReplies: 5Last Post: 17th May 2011, 17:55 -
.flv demux for audio clean up
By longislandgrafix in forum EditingReplies: 1Last Post: 29th Jan 2009, 10:17 -
VHS clean up
By tvlreject in forum Newbie / General discussionsReplies: 8Last Post: 10th Mar 2008, 00:10 -
Clean up audio on AVI file
By marybutts in forum AudioReplies: 2Last Post: 11th Jan 2008, 06:15
