Derrow's guides for splitting to 2 DVD-Rs have worked great so far for everything except this...
11 Titlesets, VTS_10 is the main movie. (5.5Gb). When playing the original on Ifoedit, it reports that titles 1,5,7,8,9,10 have been played. (correspond to VTS_10/6/2/4/3/1).
I split the DVD w/Ifoedit, it gives me VTS_10 & VIDEO_TS* by default. I copy over the remaining VTS_XX for the titles above and yet it doesn't play in Ifoedit's DVD player. It starts playing for a few minutes and then complains that a file is missing from the DVD (#$%@#$ which one?)
suggestions?
Usually when splitting in separate folder and copying the other files to complete the discs is very easy to overlook one file. In your case that will be VTS_10_0.VOB, the movie menu. Ifoedit does nothing with this file when splitting and you need to copy it separately in both folders !
If is still not working then sometimes these problems appear from the crazy way the DVD was authored. I had issues with Monsters INC and the only way to do it was to generate new VIDEO_TS.ifo's.
Anyway I think in your case is that menu. I forget somethimes to copy it in the final directory because somewhere in my mind I think that I already took care of the movie files (for you VTS_10) when splitting!
Good Luck and let me know if this was your problem !
have ifoedit build new ifo files into a new directory and copy the vob's into your new directory. This works for me sometimes.
nope, it's not the _0.VOB file, I used to do that a lot in the beginning but I usually remember now
It's Fantasia 2000 and the damn thing is really complicated. It plays 6 titles before it gets to the main movie ????? Ifoedit seems to have a problem splitting it. Even if I split to a new dir, generate new .ifo's and copy *every single missing* .vob (other than the generated ones of course), it still complains...
I've spent too much time with this DVD, I think I'll end up re-encoding it to fit in a single disc and see what happens, maybe this one wasn't meant to be split.
thanks guys
How to convert mkv to dvd with multi-audio track and multi-subtitles?
By funnybunny in forum MacReplies: 1Last Post: 6th Jul 2011, 15:21 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 17:46 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 03:01 -
Handbreak Will Not Recognize Some Titleset's When Converting DVD to IPod
By kpoman in forum DVD RippingReplies: 0Last Post: 9th Sep 2008, 10:49 -
DVD Architect Studio 4.5 Titleset Restriction
By luigi2000 in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2008, 23:05
