  1. Can any please help me........
    I have a 850mb DAt file and need it cutting into 2 so i can burn it onto a cd. How do i do thia and what piece of software?
    Thanx
  2. Hi,
    You can do 2 things :
    1st (Being the easy one) rename the file to MPG and get your self a 90min disc. It WILL fit if you burn it as a VCD !
    2nd way would be to rename it to MPG and open it in TMPGenc, go to File->MPEG Tools and select Merge & Cut.
    Greetz,
    pSyChO dAd
    The difference between genius and insanity is only measured by success !
