I've had several VCD's recently that played perfectly on my computer, yet when I play them on my DVD Player, they're completely out of syn.
Is this likely to be a DVD Player issue or is there a way of fixing this?
Are they standard VCD or XVCD? If they are XVCD it may be a bitrate issue (too high) if not I would say it is a DVD issue....they are sometimes picky. What program are you using to burn? Are you sure you are producing EXACTLY compliant VCD files?
macros746
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 05:08 -
DVD in sync on PC but not on regular player
By Perjan in forum Authoring (DVD)Replies: 0Last Post: 10th Dec 2007, 11:07 -
VCD audio out of sync on player
By burnerbie in forum Authoring (VCD/SVCD)Replies: 2Last Post: 10th Aug 2007, 13:15 -
dvd out of sync in player but not PC
By matthouth182 in forum Newbie / General discussionsReplies: 8Last Post: 2nd Aug 2007, 17:44
