    Jul 2002
    I captured some family video as mpeg1 using MultiMedia Center 7.7 and processed it through TMPGEnc(latest version) and then tried burning the cd using easy cd creator 5. I have created 2 vcd's using the same process and they work great.
    When I first encountered this problem I noticed that when I added the mpeg1 into the easy cd creator layout and then selected burn cd using layout it jumped right to the screen that you choose what burn speed you want, but when I try this on a previous mpeg1 I created it goes through the process of setting up the file before getting to this screen. Know my question is what changed. I did not change any settings anywhere because everything was working. I think I'll try a diferent capture settings and see if that makes a diference. I don't know what else to try at this point. It is getting a bit frustrating. Any help would be greatly appreciated
    Apr 2002
    The State of Frustration
    What template did you use in TMPGEnc?
    Hello.
    Jul 2002
    I ran a test with dif. template it works. Tonight I plan on burning the whole
    video which is about 1hour and 50min.
    Would anyone know why we need to set mpeg to non standard in order to view it on a DVD player that can play VCD's?
