    Feb 2002
    newfoundland
    hi i have some files thare a tiny big over 700mb's like 702 and 704(both files are .avi files) .....so when i try and use nero it comes up not enough sapce on cd-r.....only way possbile of writing it, is if u finalize the cd, so i clicked yes to finalze ...but when i try and play cd it comes up invaild or something like that.... I know that there is way to overburn on a cd-r but can anybody tell me if i need to check a option on nero etc.......my cd burner is only from december .....etc.... hopefully someone here can help me
    thanks,
    steve.
  2. Member Gargoyle's Avatar
    Jul 2001
    Southern New Jersey, USA
    Burn them as "MODE 2" - you can fit about 800M on an 80 minute CDR
    You can't fool me, I'm a moron!
    Feb 2002
    newfoundland
    do u mean in iso format and change it to mode 2/xa ....and if what im about to do is right, is that the only thing i need to change.
    thanks.
    steve.
  4. Member Gargoyle's Avatar
    Jul 2001
    Yes, thats all you need to do.
  5. NO.
    You cannot burn CD-ROMs in MODE2 Form2 sectors.
    If you burn the CD-ROM in MODE2/XA, you are still burning in Form1 sectors. That is, your max. user capacity is still about 700 MB.
    You will have to overburn. It should be okay as long as your media and drive can handle it.
    Regards.
    Michael Tam
    w: Morsels of Evidence
    universe
    yes there is an option in nero to overburn and yes you have to enable it for it to work.
  7. That's right.
    However, if you are burning an AVI file onto a CD as a CD-ROM, you will only be able to fit about 720 MB overburning at best.
    Regards.
    Michael Tam
