    Aalborg Denmark
    Check out the new features her
    with 3:2 pulldown
    ChRaN :-)
    Aalborg Denmark
    it suports direct .avs and .vdr frameserved files
    ChRaN :-)
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    nice
    Jul 2002
    Erie, PA United States
    I just took a look at it and did anyone notice the CPU requirements??
    Supported CPU
    Pentium 4 processor (2AGHz or greater)
    Pentium III processor (800MHz or greater/2 processors only)
    Thats straight off the product page. I guess if you have a Athlon processor your SOL.
    Warning! I'm baaaaaaaaack
    Sep 2001
    N/A
    I was wondering when I new version would come out and I am estatick about it.
    ONly problem is I want to use it for my dvd2cvd guide and dvd2svcd currently dosnm't support this new version at the moment anyway.
    Also I was wondering if my old "credit card" which I used to "purchase" the last version would work on this one, if you know how to get my credit card working on this one give my a Private msg or if you have a new "credit card" for me
    Baker
    My vcd & cvdGuide
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    i think the beta versions dont take 'credit cards' - they are demo mode only but no time limit .. hence the graphic ... not sure ..
    Aalborg Denmark
    Supported CPU
    You looked at the CCE pro product page this is CCE SP and i use it with my Athlon processor, no problems
    the demo on CCE homepage is ver 2.64.01.10 and it opens avs and vdr files too!
    ChRaN :-)
