I have a strange problem with encoding PAL DVDs to VCD
I use Smartripper/DVD2avi/TmpegEnc to encode using the Pal(VideoCD) template and the problem is itermittant jerkiness at various places in the movie.
To date, Ive only been able to solve the problem by unlock.mcf the
templete and using VBR max1160 average1150 min1150 which the resultin
vcd plays fine & smooth in Orion,Omni,XMS,Rowa,PS1(with vcd adaptor)and Teac players.
Problem is....Ulead DVD MovieFactory and Workshop will not accept them
as compliant mpeg streams.(Workshop attempts to re-encode, but the
jerkiness returns and the time taken to re-encode is slow)
Ive used various encoders with the results listed below:
XingEncoder..VCD is perfectly smooth & compliant...Quality is Crap Though.
CCE Cinema Craft Encoder..VCD is perfectly smooth & Quality is good.
BUT...even though i specify CBR it creates a VBR which isnt compliant.
PanasonicMPEG Encoder..VCD is smooth & compliant but quality is average
and encoding time is SLOOOOOOOW
TmpegEnc (all versions)..VCD quality is the best and compliant but jerky
when ripped from PAL dvds. (ive had no problems with NTSC dvds)
Finally a very strange thing i experimented with was to Force NTSC
playback on my standalone OmniDVD player and the video was SMOOTH!
Ive tried Vstrip,DVDpatcher but without success
Can anyone shed some light on why PAL dvds are such a pain ?
Phil
What setting do you use in DVD2AVI for Video>Field operation?Can anyone shed some light on why PAL dvds are such a pain ?
help needed for hybrid Pal dvd with issues
By spiritgumm in forum Video ConversionReplies: 16Last Post: 26th Apr 2012, 10:45 -
DVD Flick & AVStoDVD issues ...
By iCaptainChaos in forum Video ConversionReplies: 2Last Post: 9th Aug 2011, 10:19 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Toshiba DVD players & -R media issues??
By videobruce in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Nov 2007, 06:02 -
tiem dealy probs with dvd player & pvr
By TILTNTURN in forum Newbie / General discussionsReplies: 1Last Post: 17th Aug 2007, 10:21
