Hi all
What format should I use when I capture from VHS (analog) .
And I wand the best quality to author DVD (I have DVD burner)
should i use avi and after convert it to mpeg2 or direct to mpeg2?
Thx.
David
I capture straight to mpeg2 half D1 (352x576 PAL, bitrate vbr 3500kbs) using a pinnacle pctvplus board using the pctv 5.1 software.
When it works I get more or less the same quality as the original VHS tape. I say when it works because I sometimes get perfect result and sometimes I have audio sync issues. -
i capture to avi then convert and i never have the sync issue. i like avi-io then i edit that convert and burn
Done capturing my VHS, what now?
By Akerhage in forum Video ConversionReplies: 31Last Post: 27th Jul 2011, 09:37 -
capturing from VHS
By halbblah in forum RestorationReplies: 4Last Post: 1st Nov 2009, 17:35 -
Capturing VHS using All In Wonder HD
By ukcolonelcolin in forum Capturing and VCRReplies: 14Last Post: 2nd Dec 2008, 10:32 -
VHS Capturing Problem
By sdculp in forum Capturing and VCRReplies: 14Last Post: 12th Feb 2008, 16:08 -
Capturing a VHS to PC for DVD
By devnulllore in forum Capturing and VCRReplies: 14Last Post: 21st Jun 2007, 19:05
