am dividing a file dvdrip divx. Usually have no problem. I can extract the audio save the wav and the avi of part #2. The first have gives me an error "audio stream source error" Any suggestion? Also, why can I do what I need to do with the 2nd half and not the 1st.
Thankd![]()
Why are you splitting the file anyway??? If you just want to cut it in two... use VirtualDUb or IFilmEdit. Ifyr making a VCD I always do this:
Use Virtual DUb and extract the ENTIRE Audio and Video tracks first Direct Stream Copy mode), then use TMPGenc to re-encode either as one file then split using its Mpeg Tools option, or select the Source range first and tag each half at a time.
Aussie2Windows has recovered from a serious Error
-+- Can't Figure Source URL Stream -+-
By JaxGuy in forum Video Streaming DownloadingReplies: 14Last Post: 16th Jul 2013, 10:01 -
Any source to MPEG2 Transport Stream with multiply audio streams
By traaance in forum Video ConversionReplies: 4Last Post: 6th Jan 2012, 07:50 -
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 11:50 -
Sample error on separate source means video & audio out of sync!
By christowe in forum MacReplies: 3Last Post: 13th Jan 2009, 14:22 -
Virtualdub error with DV files - Audio Samples not found in source
By kbehel in forum Video ConversionReplies: 4Last Post: 30th Mar 2008, 04:40
