  1. Member Beautiful Alone's Avatar
    Jul 2002
    wow! this program is quite hard. Anyways, I'm trying to create chapters for my SVCD's. I've followed everything the guide tells me to do, and I got bunch those files..... .toc, .img etc...what do i do with these files?
    thanks
  2. Member Beautiful Alone's Avatar
    Jul 2002
    nt
  3. Member Gargoyle's Avatar
    Jul 2001
    Southern New Jersey, USA
    Open VCDeasy
    --goto "Tools "
    --click on 'CDRDAO Tools' at the top -
    --"Burn a CUE or TOC Image", load your .TOC file (click on the CUE/TOC button), click "Burn"
    You can't fool me, I'm a moron!
  4. Member Beautiful Alone's Avatar
    Jul 2002
    nope, doesn't work. Should'nt i use Nero to burn?
  5. Firstly, you should make your image as a CUE/BIN type. It is much better supported.
    Secondly, what happens when you try to burn with CDRDAO? What error messages do you get?
    Does VCDEasy say that your ASPI layer is okay? If not, I suggest that you go download and install ForceASPI from http://www.doom9.org
    Thirdly, if you can't get CDRDAO to work, you can burn CUE/BIN images with the newest versions of Nero.
    Also, these problems have been asked dozens of times before so I suggest that you use the "Search" function. It may surprise you.
    Regards.
    Michael Tam
    w: Morsels of Evidence
