Howcome it doesn't support Time Search on stand alone DVD players? hmm..works for VCD's, why not SVCD's?![]()
Results 1 to 11 of 11
I read that it has to do with most SVCDs being encoded with VBR - this causes problems when trying to FF / RW (or time search) - Not positive, though; maybe I'll burn a CBR SVCD and see how it works.
Any experts (I'm not!) out there have an answer?You can't fool me, I'm a moron! -
Here is some info that might help - something to try, at least :
andGood morning.
In my experience the FF/RW problem is down to a combination of -
no svcd scanoffsets - use bbmpeg.
PBC and scandata problems - this (amongst other things) is why i use vcdimager CLASSIC.
It creates a dummy PBC that not only allows FFRW, it also allows my TIME SEARCH option on my standalone to work; whereas the PBC on ALL vcdimagers since turn off the time search.
CLASSIC also allows mpeg greater the 99:59 mins, but you can only play past 100mins, not search. But this is a limitaion of SVCD spec.
andtry to cut and paste the file scandata.dat in the directory ext. you can get this file at the following adress: http://www.vcdhelp.com/scandata.dat just rightclick mouse-> save as
http://www.vcdhelp.com/forum/viewtopic.php?t=76226&highlight=svcd+rewYou can't fool me, I'm a moron! -
I encoded all my SVCDs using VBR and I can do time search in my standalone DVD player although the time is not correct. The DVD player always show the total time is 40 min no matter what the real length is. I always multiplex video and audio in bbmpg with SVCD scan offset.
so..how do i encode it with VBR?Originally Posted by vince
Thanks -
You have to calculate the bitrate using FitCD and choose the 2-pass VBR and go to sleep. In CPU setting, you can choose "Save the result from the first pass". This will save you about 30% of the time.
Avi files "Not Support Video" on dvd player?
By aelfheah in forum DVD RippingReplies: 11Last Post: 12th Sep 2011, 13:18 -
I don't understand these errors saying "wrong version".
By saltyjd1 in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Mar 2011, 15:52 -
Why don't you need special "accurate" ripping programs to copy DVDs?
By sldvd in forum Newbie / General discussionsReplies: 6Last Post: 15th Aug 2010, 06:30 -
Problem with "Application Support" folder contents (& .flv co
By Fostermeister in forum ffmpegX general discussionReplies: 2Last Post: 12th Dec 2008, 14:59 -
API "SetParent" in VB6: Function & Ctrl keys don't work
By gll99 in forum ProgrammingReplies: 4Last Post: 9th Mar 2008, 20:37
