I recorded a few vcd's to cdrw's because that's what works in my dvd player. Now when i tried erease on using vcdeasy's blank cd utility it shows up that the files arent' there, but sometime it shows them as there. The disc also won't format and neither will a completely new cdrw. It says that the device is in use by another process.
Try reinstalling VCDEasy and check Device Manager to see if there is an error message for your cd burner.
Yes, I did that but it didn't work. I also tried erasing the disc in another computer and it also said it was erased and really did not.
I tested it and my burner will no longer work with cd-r's either, and i've tried different brands.
Few weeks ago I got the problem to erase cd-rw media.
I got Yamaha 6416s. I removed the cover and cleaned dust and laser lens carefully. After that, it works. You can try this if your CD writer is old.
HELP! broken mp4
By RWB713 in forum Newbie / General discussionsReplies: 3Last Post: 13th Apr 2013, 19:40 -
Broken video
By Mago in forum RestorationReplies: 9Last Post: 25th Feb 2012, 14:36 -
Broken or not broken hard drive?
By romanstopme in forum ComputerReplies: 3Last Post: 17th Sep 2009, 13:04 -
help with broken TV...
By snadge in forum Newbie / General discussionsReplies: 5Last Post: 2nd Sep 2008, 13:03 -
DVD burner Open/Close button on case is broken
By JudgeGarth in forum ComputerReplies: 15Last Post: 17th May 2007, 15:36
